Tway4231 Posted August 16, 2019 Report Posted August 16, 2019 So my two re audio srx 12” 2ohm are wired to my Rockford fosgate prime 750.1 wired to two ohms. It was working fine then one day it started cutting out. All the wiring seems fine. I have checked all my wiring by using a multi meter. The only thing i have found is that when driving and subs are connected and the multi meter is connected to the speaker wire and set to ohm or voltage it jumps up and down. But when everything is unplugged and sub box and tested on ohm is reads 2.5-2.8( crappy multimeter). I can’t tell if it’s just the crappy speaker wire i bought from auto zone(12 guage), a bad ground, or something wrong with my amp. PLEASE HELP!!! Thank you!
