bassacadia307 Posted October 2, 2019 Report Posted October 2, 2019 I’m looking to construct my system around my available electrical instead of the other way around. My goal is to stay above 12.7 volts (this is a daily build). Please advise me as to what the max amplifier power is that I could look into using with the following: Singer 390A Alt (225A idle) Northstar Group 48 starting batt and two Northstar SMSAGM480 in the trunk (501 amp-hours total) 4 runs of 1/0 power/ground between all power sources (for a total of 8 runs) Thanks for your help!
slowfkncar Posted October 2, 2019 Report Posted October 2, 2019 Above 12.7 is mostly alternator, heavy pulses of current will be buffered by the batteries. 14.4 x 225 = 3240w 14.4 x 390 = 5615w
bassacadia307 Posted October 3, 2019 Author Report Posted October 3, 2019 3 hours ago, slowfkncar said: Above 12.7 is mostly alternator, heavy pulses of current will be buffered by the batteries. 14.4 x 225 = 3240w 14.4 x 390 = 5615w Thanks. What about simply above 12v then?
BassMunky Posted October 3, 2019 Report Posted October 3, 2019 Loudd Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
