Rockford fosgate T3 6.5" comps (t3652)
AaronT
2 hours ago, White Lightning said:
Can’t find your build log to see what type of source unit / cross over networks you are using.
... or are you depending on the Amplifiers for your crossover network ???
Pioneer avh-x390bs
It's active networking mode I have it on
Better than a prs, not as good as 99prs
22 minutes ago, AaronT said:
Pioneer avh-x390bs
Oh ok, so no DSP yet. I will google you head unit and amps and give the best suggestions I can Sir ...
I would put the head unit into network mode.
on the highs, play full range down to 2.5k at a 12 db slope for your tweeters ...
on the midbass, cut the highs at 2k at a 12 db slope, then cut the low end at 70 htz at a 12 db slope ...
then 70 htz at a 12 db slope for the subs ...
bridge your t400 on the tweeters (reverse the phase) ... use no crossover on the amplifier
bridge your t600 on your midbass drivers (normal Phase) ... use no crossover on the amplifier
assuming you have the sub under control ...
This is whare I would start ... delay your left tweeter 2 ft, the delay your left midbass driver about 3 ft ... If I remember correctly, This was Ray's starting point ...
1 hour ago, AaronT said:
Cool thnx.
I do have deck in network mode. Only thing is is I can't get 70 up on mids or 70 down on subs.
Just 63 or 80
Miss read that, my apologies. Should work fine ... keep me posted ...
Also I have the inline (factory cover) in use for the tweeters as you told me in my first thread for Tweeter protection (they are in bi-smp mode fed through Tweeter input and tweeters on  Tweeter output)
So just get rid of them, bride both amps and run tweeters out of phase?
If the tweeters have a protective cap, it should be ok to be run in line from the amplifier. Just won’t be “fully active” ...
  • Who's Online   0 Members, 0 Anonymous, 1988 Guests (See full list)
