Just a quick (probably dumb) question..
So I just built a little enclosure for a beefy little Sundown Audio 8" sub. It is a dual 4 ohm, and before I dropped it in, I wired it up for a 2 ohm load to the amp.
Just to be sure all was okay, I checked the resistance, and it was only 1.6 to 1.7 ohms ? I've heard that the resistance of a speaker can (will ?) Change a little under a load. So does 1.6. - 1.7 ohms sound reasonable without the subwoofer actually being used ?
Yes that is totally reasonable, subwoofer impedance can change just by you talking while next to it and the vibrations from your voice changing it. I recently ordered a sundown 10 dual 4 ohm and after wiring it in parallel it sat at 1.7 ohms.
