Test tones for subwoofer amp
SuzukiGS750EZ
That hu has a setting called sub level. Put that at max. What it does is controls the pre out voltage of the sub channel. So if it isn't set to max and you have the hu at full volume you won't be using the full pre out voltage of the hu. - 5 will be safer but you may find that it isn't loud enough at less than full volume. You'll have to test it and see what you think.
So should I try 7.5? I'm just afraid of clipping. If I'm driving I don't want to constantly be waiting for it to let out the smoke lol. I just want to get max output SAFELY. I listen via android auto and Amazon music, pandora, e.t.c.
Where the hu clipped. You can test at either point, I test the rca's. Since every song is recorded at different levels it's impossible to get the most out of your amp without the possibility of clipping some songs. If you plan on playing full tilt you really need to monitor your output. - 5 will be the safest option if you have no way to monitor your system. If you use - 7.5 and start to smell the coils note where your volume is and do not go that high.
  • Who's Online   0 Members, 0 Anonymous, 5609 Guests (See full list)
