matching components to my system
Bhaazaher
Hello everyone.
so i am searching over the internet for some decent components that will match my system but i am a bit confused now..
so at the moment i am using Morel virtus 602 components with JBL GTO19T tweeters(i fried the morel ones and replaced them with the jbl)
as for the amp i am using audison SR4 (currently using 4 ch but willing to go for 2ch)
the amp gives in 2 ch 175W X 2 @ 4 OHM
Running a 1000 RMS DC AUDIO level 3 sub
so i am looking for components that will match the system and the amp
+ people are suggesting that i should add 6/9 speakers and i dont think its a good idea since i have a kia rio sedan and i dont have 6/9 in the rear
what should i do?
get another components put them on the rear on 4ch
get a better components and run them on 2ch
or go for the 6/9 in the rear?
Thank you all for your time
what does the amp put out for wattage in 4 ch mode? What the rms ratings of the Morels?
What is the issue w/ the speakers you have now?   Not loud enough? Not enough mid-bass? What are you goals.
Your not putting enough power to your components. 2 ch would be fine but you would need to set your gains properly and you would be fine. If you set them by ear then you would probably have distortion and could blow the speakers.
What head unit are you running?
stock? aftermarket?
You could sell that amp and get a 2 ch with more power or a 4 ch with more power?
an aftermarket headunit.. its a jvc kw-v21bt
and for the amp i guess it produce enough power.. as you can reach 350W RMS for a pair in 2ch @ 4 ohm
the problem i can't find a decent components that can handle that RMS
27 minutes ago, Bhaazaher said:
4 ch @ 4 ohm = 65W RMS  X 4
4ch @ 2 ohm = 90W RMS X4
the morel = 140 watts RMS (300 watts peak power)
Is this the amp ratings?
  • Who's Online   0 Members, 0 Anonymous, 1164 Guests (See full list)
