Help and suggestions please
7 minutes ago, bcbrassard said:
I am just trying to give you some info.  I am no professional but i know whats working out there.  Your not happy with it so maybe his way doesn't work. ?
Good luck!
Thanks for your input will await others aswell.appreciated
I just wanted to say the resistors are absolutely needed for the way he did the installation. Those Dodge trucks will stop putting out a signal if you just wire up a regular loc without any load. But as others have said there is a much cleaner and easier way to do it. By using a PAC Amp Pro. If you wanted to switch over to the PAC piece you would have to tear everything he did out and reconnect all the stock wires.
Would rather not but you're correct.
