About 6 months ago we put a head unit and door speakers in my son's truck is done correctly with a mounting kit and wiring harness everything was fine the other day we installed two subwoofers and an amplifier again everything was fine yesterday it stopped playing music I checked all my wiring all my connections everything was good so I assumed it was the head unit (it was one of those $20 blaupunkt Toronto's) so we went out and bought a new head unit installed it same thing no sound then I found that if I unplug the wiring harness for the speakers and plug it back in they'll play for 2 seconds and then no sound again so I left it unplugged and I can get the subs to come on and play but as soon as I plug the door speakers back in I lose sound again I ohmed out the harness for the door speakers and I'm getting 4 ohms on each I thought maybe one had blown and was shorting out any thoughts the trucks done so I don't want to rip it all apart again and it's middle of Winter. Thanks for any help
Yep, agreed short on a speaker wire. U can use a multimeter at the head unit and check every speaker lead with an ohmeeter ( mine has a beep instead of a reading for continuity) , but ground one lead if meter and test each speaker wire, one will show u an impedance reading ( or beep if it's does that and that will tell u which wire is shorted to ground and let u know which door to start looking in). I have seen some poorly mounted door speakers have a terminal touching the door cause a shorted wire, usually it from someone who used drywall screws to mount them tho.
I wound up putting spade terminals on the speaker harness and disconnecting them 1 at a time till it started playing again. It was the passenger rear speaker. He's got sound again. We'll pull it apart in the spring. Thanks for the help 👍
51 minutes ago, repobud said:
I wound up putting spade terminals on the speaker harness and disconnecting them 1 at a time till it started playing again. It was the passenger rear speaker. He's got sound again. We'll pull it apart in the spring. Thanks for the help <img src=">
Good deal, it happens alot and that's why I quit using anything but big head self tapping screws with foam tape and premade adapters to mount door speakers long agao. Not saying it's the speaker mounting in the door but I'm willing to bet it is lol
