so i got:
optima yellowtop under the hood
kinetik hc2400 on the back
iraggi 240/165 amp alternator
it was running fine for about a week since i installed it,
my voltages were:
14.2@idle, 13.4v w/ engine off
this morning it was running fine too
so when i was leaving this afternoon, i noticed the battery gauge was pretty low
i checked the voltage and it was only 12.7 while the car is idling and system is off
so i turned my car off and checked the voltage, it was 12.8
so i disconnected my powerwire that runs to the back battery and the amps
after about half hour driving
i checked the voltage, while idle it was 12.3
when it was off it was 12.5
what do you guys think? did my alternator died?
i checked all the wire connections and it seems that its good
your alternator is not charging properly. make sure your belt is nice and tight. if your belt is already tight....you may want to check that alt
thanks for the help me ill check it the belt if its tight..
how will i know if the belt is tight enough?
(sorry for the dumb questions, im new to this)
sometimes when i start my engine there is a high pitch noise, do you think its because of the belt?
does that mean its not aligned or its loose?
i just checked it, the belt is nice and tight
my voltage:
12.46 engine off
12.21 engine on
don't tell me my alternator is dying... i just got it a week ago.. omg..
what do you think?
i had a similar problem but different brand alt...
my problem was i had low oil in my car and made it hard for the engine to turn anything car ran fine just had the squeel got an oil change and it stopped
so check your oil
  • Who's Online   0 Members, 0 Anonymous, 4539 Guests (See full list)
