My head unit has a digital out which is coax which I run into a 12 channel dsp. I dont use rca Jack's but a digital signal, the dd-1+ isn't reading anything using that connection
You can test the radio from the output of the DSP if you want. I tested mine all at the amps, you just have to start with everything to flat (EQs, boosts, etc...), gains/levels to minimum, and work your way back from head unit to amps.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
