2500 watt class D "ground pounders" for $200 .. anyone know if these amps are worth crossin' paths with, and what kind of numbers they would ACTUALLY do .. just seams surreal to me :ph34r:
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
The GP2500D amps do about 1,000-1,200w RMS.
if this is the one your talkin bout Crunch GP2500D then yes they are good amps... there are a couple of people that run that amp on this site
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
actually aren't the crunch amps unregulated so it actually depends on how much voltage you feed it... cuz i've heard people claim it to be way under rated so if u give it the normal 14.4 volts that many people run there systems at i think you can hit 2500wrms easily if not more
2500 watts may be possible with a 16 volt system and this amp, but I'm only getting 2800 out of my Crunch GP Pro 3000D at 1ohm. The impedence rise is from 1 ohm to 2 when played and is seeing a constant 14.8 volts. The 3000D is capable of 4000-5000 watts on a 16 volt system and a low reactive load.
i'm quite sure with that misslink module, you'll see more than enough juice from that amp along with a good battery underhood and in the rear ................
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
would it be cheaper to just run a hifonics amp? i'm only lookin' for 1250 - 1700 watts, that's what i asked cause i figured they were underated, unless someone knows a better amp around the same price?
Team T3 Audio
Team Sundown Audio
Team O.B.M
at wat ohm load are you lookin the 1250-1700?
1, D2's wired in parallel
Team T3 Audio
Team Sundown Audio
Team O.B.M
is that one sub dual 2 ohm wired in parallel if thats wat ur tryin to say then thats a one ohm load so u want 1250-1700wrms at one ohm?
