realflow100 Posted April 13, 2020 Author Report Share Posted April 13, 2020 Only issue is I'd like to have the option for them to be in separate boxes. in that case I would just need to order a custom sized sealed box from some speaker-box-builder website of some kind. I dont have any hardware to put it together myself. so it would likely be expensive to have 1cu ft sealed boxes for 6x9's Link to comment Share on other sites More sharing options...
AaronT Posted April 13, 2020 Report Share Posted April 13, 2020 1 hour ago, realflow100 said: Only issue is I'd like to have the option for them to be in separate boxes. in that case I would just need to order a custom sized sealed box from some speaker-box-builder website of some kind. I dont have any hardware to put it together myself. so it would likely be expensive to have 1cu ft sealed boxes for 6x9's You can get a 2 12" sealed 2.2 cubic foot box from Amazon for 60$. Cover hole on front. Put 2 6x9 per chamber. Or knock out center divider so they all share same air suspension. Ground shaker makes a sturdy 3 12 box sealed for like $100. That's an option as well But if taking on such endeavors, why not bump up the 6x9 quality a bit. Either way they all should sound decent. I had some Rockford Fosgate t1652 6x9s they literally sounded like a small sub stage Link to comment Share on other sites More sharing options...
AaronT Posted April 13, 2020 Report Share Posted April 13, 2020 The thing is with a custom box builder is you're not needing anything ported, so having someone build a sealed box would be cost prohibitive. Bare minimum they ain't gonna touch a box build for under 200 id imagine And let's say you have him build a 2 cubic foot box, well 200 for "custom work" or pay the $60 for a pre-fab same dimensions. We aren't putting big subs in it, so nothing the pre fab couldn't do that the custom could. Link to comment Share on other sites More sharing options...
realflow100 Posted April 14, 2020 Author Report Share Posted April 14, 2020 I do have a box for 2 12's but its ported. I'd need to seal the port or something to give it cleaner sound. and also would need a large board with two 6x9 cutouts in it. as far apart as possible for best stereo sound. I'm not sure where to get cheap boards from though. and all I have is wood glue to glue it on with. not even any nails. I think it would be better to just wait and save up until I can find some kind of better enclosures. Link to comment Share on other sites More sharing options...
bmwking Posted April 14, 2020 Report Share Posted April 14, 2020 wayyyyy back in the day, like 20 years ago, i installed some excelon 4 way 6x9s in the back deck of a lumina sedan on a 200w full range amp. obv they were infinite baffle due to rear deck oe replacement mounting. those things slammed like he had a couple of 8s at least. i was blown away that 6x9s could make that much sound. it can be done, tho i'm not sure what would be the best way to go abou tit Link to comment Share on other sites More sharing options...
