1point21gigawatts Posted April 22, 2020 Report Posted April 22, 2020 1/0 gauge supports 350 amps of current. So 2 runs support 700 amps and 3 runs support 1050 amps. 3 runs doesn’t make sense because instead of 3 runs of 1/0 you can do 2 runs of 2/0 gauge “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
1point21gigawatts Posted April 22, 2020 Report Posted April 22, 2020 1 minute ago, bismofunyuns said: so if the amp only has two power and ground, would make more sense to just run two each from the alt? Yes “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
1point21gigawatts Posted April 22, 2020 Report Posted April 22, 2020 Double up on your ground connections too “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
1point21gigawatts Posted April 22, 2020 Report Posted April 22, 2020 What kind of amp is it? “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
1point21gigawatts Posted April 22, 2020 Report Posted April 22, 2020 https://toolmakermetalworkz-com.myshopify.com/collections/frontpage/products/aluminum-dual-1-0-alternator-block-ring “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
bismofunyuns Posted April 22, 2020 Author Report Posted April 22, 2020 2 minutes ago, 1.21gigawatts said: Double up on your ground connections too so basically what i had, just 2 runs instead of 3. and double runs to both the chassis grounds right? so if the 1/0 can handle 350 amp, i should fuse 350 instead of 300 right?
1point21gigawatts Posted April 22, 2020 Report Posted April 22, 2020 Get two of those and do 2 double runs on the alternator. On the ground of the alternator run dual runs from that to your front battery negative. And run dual runs from the alternator positive to the positive post of your front battery. You don’t have to fuse it. The do dual runs from the front battery to a fuse holder under the hood then run it to the back to another fuse holder and then to the rear battery then to another fuse holder then to the amp. And make sure you do a double run from the front battery’s negative post to the same spot as the factory ground which will be to the chassis or frame. Then do a double run from a spot on the frame to the engine block. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
1point21gigawatts Posted April 22, 2020 Report Posted April 22, 2020 Just now, bismofunyuns said: so basically what i had, just 2 runs instead of 3. and double runs to both the chassis grounds right? so if the 1/0 can handle 350 amp, i should fuse 350 instead of 300 right? I use 500s. But yeah you can use 350s. I’d use 500s but I like to have head room so when I upgrade wires and my system I don’t have to buy new fuses “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
1point21gigawatts Posted April 22, 2020 Report Posted April 22, 2020 https://toolmakermetalworkz-com.myshopify.com/collections/frontpage/products/aluminum-dual-1-0-alternator-block-ring Get two of those and do 2 double runs on the alternator. On the ground of the alternator run dual runs from that to your front battery negative. And run dual runs from the alternator positive to the positive post of your front battery. You don’t have to fuse it. The do dual runs from the front battery to a fuse holder under the hood then run it to the back to another fuse holder and then to the rear battery then to another fuse holder then to the amp. And make sure you do a double run from the front battery’s negative post to the same spot as the factory ground which will be to the chassis or frame. Then do a double run from a spot on the frame to the engine block. “How can we help you?” “And don’t forget to tell them that the customer isn’t always right.”
bismofunyuns Posted April 22, 2020 Author Report Posted April 22, 2020 4 minutes ago, 1.21gigawatts said: Get two of those and do 2 double runs on the alternator. On the ground of the alternator run dual runs from that to your front battery negative. And run dual runs from the alternator positive to the positive post of your front battery. You don’t have to fuse it. The do dual runs from the front battery to a fuse holder under the hood then run it to the back to another fuse holder and then to the rear battery then to another fuse holder then to the amp. so basically like this?
