Amp for 180x4
Superchargeme
So I'm needing to get an amp that will put out around 180x4 rms at 2 ohms for my mids and highs. It's powering 4 pairs(8 woofers, 8 tweeters) of morel maximo 6 components. I was looking into getting a barbara ann from us acoustics, but unfortunately they said they won't have them stocked for at least a couple more months. I really don't want to have to wait for months to get my system installed. I know hertz and zapco have some options that would work for me, but they are a little more pricey than what I would like to pay. The taramps ds 800x4 2 ohm looks like it might be a little noisy. Soundqubed has the s4-100 that could work, but once again looks like it might be a little noisy. The crescendo s4 might fit the bill, but can't seem to find any specs. Don't want to go the skar route. What other options do I have to go with? Would prefer to keep the amp under $300 if possible.
This amp is underrated probably more like 180-200 rms .
This is coming soon if you can hold on , would for sure do over rated power.
The Taramps DS800x4 could fit your needs....or 1200x4 if you wanted head room.
Fixed Hp/LP at 90hz could be an issue tho depending on the rest of your setup
07 Dodge Ram Mega Cab 3500 SRW 5.9L Cummins Twin Turbos (fraternal not paternal;) 3x 12" 11sL7 2DVC wired to 1.3ohm on Nesa Encore TS Power TE-5000D amp, Kicker 6.5 Q class Components front and rear doors on Memphis PR4x50 amp, Big 6 upgrade for dual Group 34 Yellow tops. Pioneer DEH8400BH HU.
2016 F6B Goldwing infinity Kappa 50.9CS(factory amp) front and 60.9CS rear(Taramps DS 160.2 Mini amp)
1 hour ago, Superchargeme said:
It can be worked around at least.
Meaning Hu, DSP, Active running the amp full range? I assume
This is on sale 150x4 at 2ohms , I’m sure it puts out more .
  • Who's Online   1 Member, 0 Anonymous, 1855 Guests (See full list)
