Shibby Posted May 13, 2008 Report Posted May 13, 2008 So I am feeling lazy and am thinking about using aeroports instead of building a port. Dont really know how much port area to use. Going to be 2 12" l7s in a 4.5-5 ft2 enclosure. Dont know exactly cause its all fiberglass and havent finished yet. I was thinking of doing 2 4" ports but dont know if that would be enough. Thanks for the help guys
Shibby Posted May 13, 2008 Author Report Posted May 13, 2008 Damn I was hoping 2 would work, maybe I should just build the port, ya im a little lazy and cheap, thanks for the help
Shibby Posted May 13, 2008 Author Report Posted May 13, 2008 ok so now im thinking about going with three 4" areoports anyone see a problem with that, will there be much port noise, im sure someone has done something close to this
Noobtastic14 Posted May 13, 2008 Report Posted May 13, 2008 three will work but is not best case scenario. 4.5cuft w 14sqin of per per cuft = 63sqin of port for the single chamber. 2*2*pie= 12.5sqin of port per 4" pipe 63/12.5 = 5.04 so five 4" pipes will get you 14sqin of port per cuft assuming its net 4.5 internal. less will work, but port velocity will increase with potential for noise (somebody correct me if i'm wrong) -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
Derrick824 Posted May 13, 2008 Report Posted May 13, 2008 You'll be fine with 3 but I'd rather see you do 4.
andym85 Posted May 13, 2008 Report Posted May 13, 2008 You'll be fine with 3 but I'd rather see you do 4. agreed i likes me some audio stuff...
Shibby Posted May 14, 2008 Author Report Posted May 14, 2008 thanks alot guys, i have a lot to think over, hate port noise, have to buy another sheet of wood just for sub rings, so i will have to figure it out. starting next weekend so i will post pictures
