akuma4u Posted July 9, 2020 Report Posted July 9, 2020 Hey just want to know if its ok to connect two agm batteries in parallel if one is a medium size and one large size or one is 50 ah and the other is 110ah? Will one make the other deplete faster? Should both batteries be the same size/model?
Dafaseles Posted July 9, 2020 Report Posted July 9, 2020 You should be good. I was told you could mix sizes and brands... just don't mix chemistries. It's to my understanding the chemistry of the AGMs are all the same. So size really doesn't matter 2011 Chevy Silverado under construction My build log here. Check it out!
fishchris1 Posted July 10, 2020 Report Posted July 10, 2020 ...or, obviously voltages, but two 12 volt batteries should be fine.
Dafaseles Posted July 10, 2020 Report Posted July 10, 2020 25 minutes ago, fishchris1 said: ...or, obviously voltages, but two 12 volt batteries should be fine. Good catch, didn't even think about voltages 2011 Chevy Silverado under construction My build log here. Check it out!
