T line, 4th order, sniper on single 8?
Pieter
Im in need of some help to a box design for a single 8 inch subwoofer using specs of a sundown x8 v1. 5 as the woofer i have i can not find a spec sheet for but fs should be close to the sundowns, the idea is to play from 20hz upwards nice clean and groundshaking bass if possible but with a limited boot size of around 900mm long by 450mm wide and 600mm high what would you guys think will work best?
You listed t line, then ported and 4ths.
The T-Line dies not peak, it plays flat (if done right)  IMHO the x8 is not a T-Line candidate.
I'd say 4th, you have a good bandwidth with that and you can tune ported side low.
Just put that subwoofer in a regular ported enclosure. Sub back, port back. And a 4th order enclosure could fit it that car easy. You would have to put the back seats down for the blow through to breathe and when the back seats are up the blow through (which would be facing forward) wouldn’t be able to breathe, so turn the subwoofer off when the back seats are up. But if you don’t wanna do that then do a regular ported enclosure with subwoofer and port facing back towards. the trunk hatch. You would have to recone it after awhile of bumping on that soundigital 3k. So be conservative on the amps gain and don’t clip, AT ALL.
:guido:
  • Who's Online   0 Members, 0 Anonymous, 607 Guests (See full list)
