How is my enclosure for SPL?
3 minutes ago, 1point21gigawatts said:
THE VELOCITY IS WAY TOO LOW AND AFFECTS THE OUTPUT IN A NEGATIVE WAY.
What is that calculator and where did you get those values? What should I make the port area?
1 minute ago, 1point21gigawatts said:
When it comes to port area just add 16sq” per cubic for of the enclosure, or close to.
My original that you said was way too low was 18sq" per cuft assuming we're talking net enclosure.
And when it comes to slot port velocity, I like to stay anywhere from 10 m/s to 25 m/s. Over 17 m/s is when risk comes into play.
:guido:
Too much port. I said the velocity was way too low. Too low for a slot port.
:guido:
Send me measurements of the area available and I can design you an enclosure that will slam hard as fugh and make people jealous.
:guido:
max size is W 31 x H 14 x D 30
 And I already sent this design to be made so I have to work quick if I want changes, I appreciate the help.
Which way do you have to port firing? Because the figures you first posted would only work if it was port up but then the measurements of the port tells me it’s in the front or side. If so then that port doesn’t have enough room to breathe and that enclosure is gonna act as a big sealed enclosure and sound like shit. A port needs at least its own width of area in breathing room from a inner vehicle wall.
:guido:
Sub on top port on side. Ignore the 8in, I couldn't put sub on top using this software. And I don't know what you mean the port is huge???YI4jEht.png
  • Who's Online   0 Members, 0 Anonymous, 1094 Guests (See full list)
