56 minutes ago, killerc998 said:
No good way to do wiring so I just ran it like that. IMG_20211010_140642.thumb.jpg.94ed62ba712683c3b386df343be68408.jpgIMG_20211010_140724.thumb.jpg.4772b978e06fbff52bf410725e528e1a.jpg
Could be worse
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
Also ran out of 2/0 so the 2 runs from the headways to tothe  fuses are 1/0 will replace once i get more 2/0. Temco industrial that makes it is out of black. So I have to wait for them to produce some.  Each ground is ran to the frame. Got 10 frame grounds. I like to over do wiring.
19 minutes ago, killerc998 said:
Look at the door flex NICE!!!
06 Charger
Pioneer double din
Xs power d3400
2 hours ago, killerc998 said:
Sounds good, door gets more flex with different songs. With the lithium i hardly see below 13.8. Normally it sits about 14.2 on heavy bass songs.
That's perfect! Good job man
  • 5 months later...
Decided to do front batteries delete. Use a Jim's Machineworx fuse block.  Voltage is 14.5/8 at idle. Full till it drops a volt. Got 40 more headway lifepo4. Going to add and have a total  144Ah.  All that wire. 2 runs of 2/0 welding wire from 270alt, 1 run 1/0 from 145alt to fuse block. 2 runs 2/0 to battery, one run 1/0 to the air compressors and mid/high amp. IMG_20220409_134844663_HDR.thumb.jpg.f4452e9e362d1ee3dbd0028cc3d5f027.jpg
Nice!
So I had to replace the mid/highs amp. It's starting to go. You could listen to music loud/low and on occasion you would get no sound for a few seconds. Tried different RCAs/deck same thing. I also did a complete front batteries delete/added headway cells.  Cells were charged then connected. Since they are used from batteryhookup.com instead of being 8ah per cell they are prolly 5ah at a min, so we can say 100ah minimum. Can I play all day and voltage not drop yes. Also fuck Google photos. New phone saves everything to it. And I don't like it. 454499550_IMG_20220420_1642458002.thumb.jpg.cc29c2ad2c828429aac0113f88ae98a2.jpg
  • Who's Online   1 Member, 0 Anonymous, 970 Guests (See full list)
