Okay like the title says, what would be my best bet for Ground Pounder subs? So far I plan on 2 18" BTL's with 4krms, ripping the back seat out and firing subs/port into car, sealing off the trunk, and tuning around 32-34Hz.
I imagine 6 12's in the same set-up would probably be more of a Ground Pounder?
Also, what subs would be better than BTL's for Ground Pounding?
Would 6 12" BTL's do it better than 2 18's?
Thanks for any input guys! :)
Derp.
I got the whole back seat and trunk to play with for space :D
My trunks fairly big, not sure on cu.ft. I'll find it out eventually. ;)
Derp.
Whatever makes me get loud I am up for!!
Is it a wall if you make it below window line? Or is that a mini-wall?
Either way, if I have too a wall right behind the front seats will work to! :D
You think going all out like this is the way to go for a Ground Pounder?
Derp.
my old "1/2 wall"
sounded good.
do the same but much, much more cone area
-Drew
uhoh_45 said:
I mean I don't know what the prerequisites are of a GP are but I would assume at least 150 and hair tricks or maybe just hair tricks IDK. But yeah the way to be a GP is to get loud. Just tune low and a lot cone surface. I would still measure and see how much space you have.... What car?
Rebuild coming soon
6 12's would be more like frankie rios setup
Edit: nvm its 12 12's
Edited by Sp33dyG
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
