Bigger than Average System Plans - Comments Please
Good morning,  I am seeking comments back on equipment selection for this build.
Goals: For now = Demo Vehicle , windy af with the ability to sustain half day sessions.   I have an HHR Panel I was going to use but by the time all the equipment is in.. she would be dangerously overloaded.  HHR not enough room either.  Going with either a Suburban or Cargo Van.
Just focused on the Sub part of this system for now.
Considerations =
Wall Build. 4th order ?
Parts Planned out as of now.
Head Unit?
SubSonic Filter/Crossover?
Amps = (2) Orion 3000.1DSPX
Subs = ?  Neo magnets or ?  Was planning on hitting the amps with 1 ohm
Electrical =
(1) Stock Alternator
(2) Mechman 370 Elite externally regulated.
I am wanting to run 14 volt batteries.  The 2 Caps I have say not to go over 14.8 Volts, that doesn't leave much room?
(2) XS Power SB1260-31 Super Caps.
Need a Budget friendly recommendation for the Reserve Ah Stack?
Thanks for any comments.
Well, in my opinion, walls tend to move more air than a regular fourth order, but a fourth order wall, you'll get more lows.
Head unit, I've never had a problem with my pioneer, though I've heard kenwood and alpine are great as well.
Subs, you know the deal I'm sure. There are a ton of great subs out there. If you plan on a fourth order, try to find a sub with a QTS higher than .5, if you're going to go straight up ported wall, a QTS lower than .5 is optimal.
As far as the electrical, I don't know much about super caps. I do know lithium and lithium banks do great, though I don't know if you can mix lithium and a super bank. If you find out you can, get some Ying Long cells and build your own. Fairly inexpensive.
That's my 2 cents.
  • 2 months later...
  • Who's Online   0 Members, 0 Anonymous, 1611 Guests (See full list)
