Battery help: AGM
On 5/26/2021 at 11:33 AM, BassMunky said:
Losing voltage???? What could be this then...
Ur not loosing voltage , it's because at idle the alt outs out less than at cruising speed ( around 2k rpm), every alt has an idle rating and a higher ROM rating . Its normal, I'd suggest charging the batteries overnight on 5a or so bc if they were run low when the alt wasn't working u could be less than 100* voltage. Jut my two cents tho.
There brand new...
Also
How I know if a Diode dead or bad I put 2 in line with the sense wire upping the voltage. Been on the electricial sense wire for the alt for over 10 years
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
  • Who's Online   1 Member, 0 Anonymous, 351 Guests (See full list)
