Helix component sets or other
I have a 2017 Toyota Corolla SE and I am planning to use the Helix C62B component set active on a Helix G4.
My dilemma is that I am pondering if this set would be good with Trance music or should I go with something else for example:
BLAM
Rockford Fosgate T1
If you have any suggestions for a 2 way set that meets the following fitment criteria please let me know.
6.5 opening with 2.67 depth
1 inch tweeter with 1 inch depth
Fitment information was retrieved from CrutchField a few months ago.
Thank you for all your help.
I've heard nothing but good things about helix equipment. Same with BLAM and fosgate. I don't think you'd be disappointed with any of those options.
I've also heard good things about Audio Frog and CDT. Might be worth looking into as well
I was running the same Helix component set in my Toyota Yaris and they were great (I also had a 3" audio frog mid range).  I ran the tweeter and mid range from 1 G-Four and the mid bass to the 6.5" with the other G-Four.
Can I assuming that you don't have a subwoofer? I had my mid bass cut off at 80 hz with a 12db roll off on my DSP. The 2 way set up will sound well off the 1 amp but you maybe pushing the 6.5" if your set up going to be tuned below 55-60hz.
