Smaller than recommended ported enclosure?
RobbyMayI
I have a single cab RAM 1500 that can only fit up to about a 2.7 cu. ft. enclosure. I currently own 2 Sundown Audio E-12 v4s with a recommendation of 1.75 cu. ft. per sub ported. Is it feasible to achieve good bass with port tuning or is it too far away from recommended specs?
What are the dimensions you have to work with?  Can't say for sure without knowing that.  How much power are you going to be running?
Builds:
The enclosure dimensions are 60" × 10" × 17". I'll be powering them with an Elemental Designs NiNe.1 @ 1 ohm so roughly 1200 watts.
Oh yeah, you can totally work within that space.  Let me see if I can come up with something for you.  I assume you are going to want to tune to the low 30s?
Builds:
Preferably the low 30s. Thanks for your help!
This is what I would do with that amount of space.  Its ~3.2 cu ft net tuned to 32 hz with just under 50 sq in of port area.  If this looks good to you I'll give you a cutsheet.
Builds:
Oh wow. That rendering came out phenomenal! Thank you so much for your efforts. I will do my best to keep you posted on my progress.
That's nice wanna help me with a box lol
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
  • Who's Online   1 Member, 0 Anonymous, 1262 Guests (See full list)
