Ok so I'm trying to do this the easy way till it's warm out again there's snow on the ground it's exceptable to have a ground wire running from both batteries to the amp right
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
You have 2 grounds from your amp, with a single ground going to each battery?
Not yet seeing if that will work cause the 1 ground is to my xs power battery and to get to that I have to take out the box but I can get to my other battery easy it's snowing out and cold so I'm trying to do it easy and fast
06 Charger
Pioneer double din
Xs power d3400
Just trying to add a ground to the amp without doing extra stuff I don't like the cold
06 Charger
Pioneer double din
Xs power d3400
If you're asking can you ground the amp to a single battery, then yes, you can. Just make sure the batteries are grounded well themselves
Both batteries are grounded to factory spots different locations my amp is grounded to the xs power battery but wanna add a second ground but I can only get to my duralast battery without doing extra stuff was wondering if that would matter so 1 ground coming off each battery and going to the amp
06 Charger
Pioneer double din
Xs power d3400
If the batteries are wired in parallel together, then essentially, you have 1 big battery, so I don't see anything wrong with that.
The power wires are connected but the have different grounds I think that's the same thing
06 Charger
Pioneer double din
Xs power d3400
Just took the 1500 out and put the 3500 back in soon as I figure out how to download the video I'll show u some flex
06 Charger
Pioneer double din
Xs power d3400
Big difference between the 2?
