Never Enough Bass Posted September 2, 2021 Report Posted September 2, 2021 Ok so I got the highs down now need the mids I'll have 2 12's in the trunk and I also have this hole in the rear deck that will fit a 8in sub I already have an extra amp but it's a sfb 1500 what free air sub can handle this amp gonna us it as a mid also maybe run it at 4 ohms like 700 rms lol or am I doing to much 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
Dafaseles Posted September 2, 2021 Report Posted September 2, 2021 5 minutes ago, Never Enough Bass said: Ok so I got the highs down now need the mids I'll have 2 12's in the trunk and I also have this hole in the rear deck that will fit a 8in sub I already have an extra amp but it's a sfb 1500 what free air sub can handle this amp gonna us it as a mid also maybe run it at 4 ohms like 700 rms lol or am I doing to much Different type speakers are built for different things. An 8" sub isn't going to be able to play high enough frequencies to be a even a decent midrange or even mid bass. I think it'll hurt sound quality more than it will help. They do make speakers that can be dedicated mid bass, and also speakers just for mid range. But usually mid bass speakers won't play high enough to be good dedicated mid range speakers. So you'd have to run a 3 way setup. 2011 Chevy Silverado under construction My build log here. Check it out!
Never Enough Bass Posted September 2, 2021 Author Report Posted September 2, 2021 I figured I was doing to much I think I'm just gonna have to make or get some door pods and figure this out even tho I'm still without the subs right now cause the damn part store didn't have the last ring terminal I'm short 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
