Audio Control LC8I
Dafaseles
So, my coworker bought an Audio Control LC8I. One he buys the rest of the stuff, we're going to completely redo the system in his Escalade. Door speakers and add subs.
My question is, how do you install an LOC? I get the basics. Intercept the audio feed somewhere before the factory amplifiers, run power, ground, bla bla bla. But where would be the best place to Intercept it?
I read the manual. It's a little foggy because I'm not sure where to Intercept the audio. I think that's the only thing I'm foggy on really.
It's the Bose system of that matters.
Any help would be helpful
In the dash behind the radio
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
Some factory amps are in the dash so that's probably your best spot
06 Charger
Pioneer double din
Xs power d3400
I'll have to find a radio wiring schematic of the truck won't I?
That or take the door panels off and look at the speaker wire and just find a switched 12v wire like the cigarette lighter
06 Charger
Pioneer double din
Xs power d3400
That's how my hu is wired cause in my wiring harness there isn't a switched 12v so I had to tap into the cigarette lighter
06 Charger
Pioneer double din
Xs power d3400
Your changing door speakers anyways so it'll all be right there just gonna have to do that part first and remember the wires
06 Charger
Pioneer double din
Xs power d3400
I'm going to pull all the speaker wire out and replace it as well. I just have to find where the amps are so I make sure to cut power to those as well. I don't want them messing with the signal at all.
I've never messed with keeping the stock radio, so this will be interesting.
I would think there would be a switched 12v going to the factory amplifiers wouldn't there be? Or no?
Yea there is you just have to look at the radio schematics it should be on there it's not that hard the amp is just a pain it could be behind the glove box or in the back behind the side panels if you look on Crutchfield it'll show you where it's at
06 Charger
Pioneer double din
Xs power d3400
Yea you can just find the wire in the harness and pop it right out no more factory amp but like you said your gonna have to rewire
06 Charger
Pioneer double din
Xs power d3400
  • Who's Online   0 Members, 0 Anonymous, 1114 Guests (See full list)
