Warm cones, funky smell.. Need help locating the problem
whoopdeedoo
Any ideas?
  • 2004 Tahoe Z71
  • Pioneer 80PRS
  • Taramps Smart 5
  • Sundown Xv3 15" (2)
  • Mechman 320a
  • XS Power D3400 (2)
  • KnuKonceptz wire and RCAs
  • Slam Panda knob (RJ45 model)
Subs may be fucked
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
Loose connection
06 Charger
Pioneer double din
Xs power d3400
On 10/5/2021 at 8:03 PM, whoopdeedoo said:
With everything turned off, no vibration wind or noise.
The ohms would be stable unless both subs were in the box together. Again no power, movement or noise. Ohms stable on the DMM in all tests until both subs are in the box together and then it gets erratic. I've compared this to a friends 4 12's box and his stays stable. Something isn't right.
No, they are fine.
Edit ,  pull em out, put em on a table, and test em, and ill guarantee the load doesnt move. Period. Even a wrecked driver, doesnt have the load "jump everywhere". Its either a open coil (blown) or, other. A bad coil doesnt "magically jump around, when still". Period. It cant.
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
