Best way to get most out of my speakers
Without me having to do a lot of clicking on links, what subs are they? Dual 2 ohm? Dual 4 ohm? Single voice coil?
And what make and model amplifier is it? What is it stable down to? 1 ohm? 2 ohm?
I don't mean to be rude, but rule number 1 on the internet.... don't click on unknown links 🤣
I understand and should have thought about that to. Sorry the reason why I added the file is when you look at most subwoofers manual it will say nominal impedance  dvc 2 ohms or dvc 4 ohms and then pwr 500 watts but on this one its different cause it says nominal impedance 1/4 ohms and pwr 50/500. The subwoofers are Image dynamics IDQ 10 D2 V.3 and the amp is audison LRx 5.1 and I believe its stable down to 2 ohms
So they are 2 ohm subs run them in series 1 sub will be 4 ohms but when u put them together they will be 2 ohms
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
I don't see where it says the speakers are 2 ohms. Thats why I wasn't sure because of the 1/4 on it. Never seen that before
Cause it says d2 that's usually 2ohm
06 Charger
Pioneer double din
Xs power d3400
The D2 means dual 2 ohm. Meaning you can wire a single sub to either 4 ohm, or 1 ohm. I'm not 100% sure what that 1/4 is as well. I'll look into it
  • Who's Online   1 Member, 0 Anonymous, 1296 Guests (See full list)
