Dafaseles Posted June 4, 2022 Report Share Posted June 4, 2022 27 minutes ago, jnasty said: Thanks brotha!! I didn't realize how much stuff I was trying to cram where the back seats were. Definitely looks cleaner without the batteries next to the amps You definitely maximized the space in there. Looks very clean! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
jmanjr82 Posted June 9, 2022 Report Share Posted June 9, 2022 That is going to be sick! Never seen the Duracell cap wraps just durabass that look like Duracell batteries. Did you make those or buy them? Cost? Site? Can't wait to see this done!! Link to comment Share on other sites More sharing options...
jnasty Posted June 11, 2022 Author Report Share Posted June 11, 2022 On 6/9/2022 at 10:22 AM, jmanjr82 said: That is going to be sick! Never seen the Duracell cap wraps just durabass that look like Duracell batteries. Did you make those or buy them? Cost? Site? Can't wait to see this done!! Thanks man! I got them from LoudAF.net (LAF). In the comment section I write "Duracell" wraps. I did wo separate orders a few months apart before I added my other 80ah. Had no problems with either order. Honestly, a little pricey at $90 for the 12 cells. But the guy has a unique product & ya gotta support the little guys too Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director Link to comment Share on other sites More sharing options...
jnasty Posted June 11, 2022 Author Report Share Posted June 11, 2022 Did a little sealing from the rear this afternoon. foamed all rear body panels, between body & plastics then made shims for between plastics and box. Currently waiting for cure then ill work on the beauty panel. it'll be a mix of black suede and a forged carbon vinyl wrap Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director Link to comment Share on other sites More sharing options...
Dafaseles Posted June 11, 2022 Report Share Posted June 11, 2022 1 hour ago, jnasty said: Did a little sealing from the rear this afternoon. foamed all rear body panels, between body & plastics then made shims for between plastics and box. Currently waiting for cure then ill work on the beauty panel. it'll be a mix of black suede and a forged carbon vinyl wrap Looking really nice! If you don't mind me asking, what foam did you use? I'm doing something similar in a buddies car 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
jnasty Posted June 15, 2022 Author Report Share Posted June 15, 2022 On 6/11/2022 at 2:35 PM, Dafaseles said: Looking really nice! If you don't mind me asking, what foam did you use? I'm doing something similar in a buddies car Thanks! I used great stuff big gap filler.. I made sure I covered all body panels with painters tape though, just in case the plastic needs to come off for any reason Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director Link to comment Share on other sites More sharing options...
Dafaseles Posted June 15, 2022 Report Share Posted June 15, 2022 9 minutes ago, jnasty said: Thanks! I used great stuff big gap filler.. I made sure I covered all body panels with painters tape though, just in case the plastic needs to come off for any reason I'm going to have to look into that for sure! Although.... we where doing something similar... the C pillar wall turned into a B pillar wall because of hight restrictions in his crossover. It's built very funky! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
jnasty Posted June 17, 2022 Author Report Share Posted June 17, 2022 On 6/14/2022 at 9:56 PM, Dafaseles said: I'm going to have to look into that for sure! Although.... we where doing something similar... the C pillar wall turned into a B pillar wall because of hight restrictions in his crossover. It's built very funky! Give it a shot! It definitely helped BIG TIME Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director Link to comment Share on other sites More sharing options...
jnasty Posted June 17, 2022 Author Report Share Posted June 17, 2022 So I mounted them quick to get an idea, fed them from a b2 rage 2500.1 at 2ohm so they saw 2k.. Honestly thought it'd be a touch louder on 2k. Definitely over 150db for sure though (comparing to my older systems which I've metered). Either way, when all said & done they'll see 8k.. slightly more power lol. Did a little trim work & wrapped the amps in a vinyl. The beauty panel upper portion around the port will also be wrapped in the forged carbon vinyl & the lower half around the subs will be black suede. I'll have trouble wiring the amps as it's REAL tight. We'll see 🤷🏻 Vehicle: 2002 Ford Escape Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps Head Unit: Apple iPad Hi-Res Passthrough Topping d10s Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0 Sub Stage: (2) TC Sounds LMS Ultra 5400 18" Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE Processing: Helix DSP Pro W/ Dash Mounted Director Link to comment Share on other sites More sharing options...
Dafaseles Posted June 18, 2022 Report Share Posted June 18, 2022 2 hours ago, jnasty said: So I mounted them quick to get an idea, fed them from a b2 rage 2500.1 at 2ohm so they saw 2k.. Honestly thought it'd be a touch louder on 2k. Definitely over 150db for sure though (comparing to my older systems which I've metered). Either way, when all said & done they'll see 8k.. slightly more power lol. Did a little trim work & wrapped the amps in a vinyl. The beauty panel upper portion around the port will also be wrapped in the forged carbon vinyl & the lower half around the subs will be black suede. I'll have trouble wiring the amps as it's REAL tight. We'll see 🤷🏻 That's good lookin' right there! 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
