3dwin15 Posted January 24, 2022 Report Posted January 24, 2022 Hey guys i had a question can I run just one xs power d3400 to power my vehicle and power my system that is 4 sundown sa 12 (each is 750 watts) and a sundown sia 3.5k and a 320 amp alternator
Never Enough Bass Posted January 26, 2022 Report Posted January 26, 2022 Maybe try it watch your voltage 06 Charger Pioneer double din Pioneer 6.5 and 6×9's Knukoncept Krystal kable rca's 0 ga knukoncept kolossus wire Big 3 same wire ^ 1 run 8g karma ss speaker wire Sundown sia 3500d at 1ohm 2 Sundown U series 12's Duralast platinum agm H7 (Main) Xs power d3400 Trying to find a ho alt
Dafaseles Posted January 26, 2022 Report Posted January 26, 2022 Like @Never Enough Bassbass said, watch your voltage. That amount of power is pushing it, though not unheard of. Make sure the big 3 is done as well. I recommend getting an in dash volt meter as well so you can monitor your voltage at your amplifier. If it gets too low, you can turn it down, or think about getting a second battery, but you'll be able to remedy the situation before you damage anything. I've also heard from people that the full bridge amplifiers don't like a lot of fluctuations in power and can cause them to struggle, and eventually fail. So again, you can try it, but watch your voltage. 2011 Chevy Silverado under construction My build log here. Check it out!
