Skar - higher tier, smaller motor structure?🤷
I have four Skar DDR15's that have a 202oz. magnet with a 2.5"coil. I was looking to upgrade to EVL15's to get deeper excursion but noticed it has a much smaller magnet at 166oz. magnet with a slightly bigger coil at 3"; power handling is 1500 vs. 2500 respectively. Why? This makes absolutely no sense to me.
I don't know anything about either subwoofer since I've used neither/haven't read up on them. There is more to a subwoofer and what it can handle than just its motor weight though, a larger/heavier coil, stiffer surround, stiffer spider etc all play a role in what the power handling can be. For instance, a copper 3" coil is heavier than a 3" CCA coil. That doesn't mean a CCA coil is inferior, different setups call for/benefit from different designs.
The EVL's are only 1200 watt RMS. Max wattage measurements are something different and not really necessary to take into account when building an everyday system.
I can't find DDR's anywhere. Are they an older model?
