danielmax Posted April 13, 2022 Report Share Posted April 13, 2022 Hi, I have just finished an enclosure for a 15" subwoofer and tested it. Here a picture. It sounds good but I expected a more impactful bass on my body, something that hit hard. The expected tuning was around 32Hz, but the measured actually is 27-28Hz. My target isn't SQ at all, so, on the basis of your experience, increasing the tuning will do something? I was thinking something around 39Hz. Or 35, 37 will be good anyway? And what about the frequencies that can be heard louder outside the car? I want also an impactful bass over the listeners outside 😎. I remember a car meeting here in Italy, a Toyota Supra... The bass could be felt outside the car heavily on my body. But, when I look inside the car... Nothing. I was expecting to see huge boxs and subs. But I couldn't see any speaker and the trunk was filled with other things. So, I guess space isn't the only that matters. It must be the frequencies that plays and of course the power. Thank you very much, have a great day Link to comment Share on other sites More sharing options...
BumpedCX5 Posted April 14, 2022 Report Share Posted April 14, 2022 It might be worth checking your crossover settings. If the low pass is set too low you'll be chocking off a the output of the subwoofer. While tunning does play a part in output you should still be getting a good amount of volume at your current tune. For reference I have a single 15 tuned around 29Hz that will blur your vision all the way up to 50Hz where I have it low passed. This is in a crossover SUV that is bigger than your vehicle. Frequencies heard outside the car aren't within a specific bandwidth as the bass range, with sufficient output, will easily be heard. What type of music are you usually listening to that you want heard? Honestly, tunning 32-35 will slap hard for most music types and still sound good doing it. You could tune higher but output gets peaky and your bandwidth really starts getting narrow. Link to comment Share on other sites More sharing options...
stingray72 Posted April 14, 2022 Report Share Posted April 14, 2022 I can tell you why your tuning lower is because part of the port is blocked basically because its too close to the back wall. Link to comment Share on other sites More sharing options...
danielmax Posted April 14, 2022 Author Report Share Posted April 14, 2022 Thank all you for the help. I Will be around 35-37 and test it. The port is near the end of the trunk but I measured it in open air Link to comment Share on other sites More sharing options...
Joe X Posted April 14, 2022 Report Share Posted April 14, 2022 You should show your electrical and amps, the specs of your box and the specs of your sub, how did you setup gains, all that goes into it. If you don't have all those well checked you are not going to be loud with any tuning. Link to comment Share on other sites More sharing options...
danielmax Posted April 14, 2022 Author Report Share Posted April 14, 2022 I have checked all. It is loud on ears, but less than expected on the body. The sub and the amp are doing well, I'm sure Link to comment Share on other sites More sharing options...
