Chug Wysley Posted May 29 Report Share Posted May 29 Hey everyone, new to the forum and just bought a DD-1. I have been using the DD-1 to check for distortion on the factory head unit and the lc7i and the amp, but it doesn’t light up the distortion light until it’s at max volume on the head unit, max gain on the lc7i and half way up on the gain on the Rockford Fosgate punch amp. After hooking the speaker leads up and playing music, it distorts at half volume. When setting it up I used the 40hz -5 DB track. I followed the instructions on the DD-1 manual. Has anyone had this happen? What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
Chug Wysley Posted May 29 Author Report Share Posted May 29 Hey everyone, new to the forum and just bought a DD-1. I have been using the DD-1 to check for distortion on the factory head unit and the lc7i and the amp, but it doesn’t light up the distortion light until it’s at max volume on the head unit, max gain on the lc7i and half way up on the gain on the Rockford Fosgate punch amp. After hooking the speaker leads up and playing music, it distorts at half volume. When setting it up I used the 40hz -5 DB track. I followed the instructions on the DD-1 manual. Has anyone had this happen? What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
strangeduck Posted May 30 Report Share Posted May 30 use the 0db track to find distortion first. 1 Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Dafaseles Posted May 30 Report Share Posted May 30 First, try changing the batteries to a strong, name brand battery. It might sound stupid, but I've seen it work more than once. Second, did you make sure your crossovers aren't overlapping? Make sure your low pass filter is set as high as you can, and your subsonic is set as low as you can. Quote 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 31 Report Share Posted May 31 First things first,.. do you see SIGNAL ?????? Lets not worry about the distortion light yet. Do you see the 1k or 40hz signal on the dd1 first ? 1 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Chug Wysley Posted May 31 Author Report Share Posted May 31 Dafaseles, yes I did use a name brand battery, as far as the crossover settings on the amplifier, I turned it to 100hz as advised and the subsonic all the way down. Would the volume need to be set separately on the radio, lc7i and amplifier separately? Quote Link to comment Share on other sites More sharing options...
Chug Wysley Posted May 31 Author Report Share Posted May 31 (edited) Kyblack76, yes I see 40k signal light come on but the volume on the radio and the output on the lc7i both need to be maxed out. I’m pretty sure when those two are maxed that there will be distortion but the distortion light only illuminated after adjusting the amplifier gain. Is it possible that the signal is so weak that until the amplifier boosts the signal to a detectable that it isn’t registering? Edited May 31 by Chug Wysley Quote Link to comment Share on other sites More sharing options...
Dafaseles Posted May 31 Report Share Posted May 31 37 minutes ago, Chug Wysley said: Dafaseles, yes I did use a name brand battery, as far as the crossover settings on the amplifier, I turned it to 100hz as advised and the subsonic all the way down. Would the volume need to be set separately on the radio, lc7i and amplifier separately? Are you using the 0 db 40 hz tone to find the max volume of the head unit and set the gain on the LC7i? Quote 2011 Chevy Silverado under construction My build log here. Check it out! Link to comment Share on other sites More sharing options...
Chug Wysley Posted May 31 Author Report Share Posted May 31 Unfortunately the CD player does not work on the head unit so I have had to download the test tones. I’ve tried 0db 40hz and -5db 40hz. I’m going to try a Duracell battery in place of the energizer battery tomorrow. Should I just set the head unit and lc7i to 3/4 and adjust the amplifier gain until it lights up distortion? It’s weird but on the speaker outputs coming from the head unit and the lc7i, I can’t get it to show distortion at any volume, but im sure it is distorted if I had speakers hooked up. Quote Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 31 Report Share Posted May 31 Ill bet the oem source level is to low. But, sure, you could set the source up at 7/8s of max, same on the lc7, then, run the dd1 with the amp, and adjust accordingly. Hopfully you dont have a cock ton of floor noise. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
