if u dont do 2 full length runs of negative then i would do 2 negative from your front battery to the frame and 2 negaives from your rear batteries to the frame, then negatives from rear batts to amps. things just need to be equal for current flow issues
i likes me some audio stuff...
alright well i can def do that! thanks man. is 2 grounds from engine to ground required too? or just all batteries?
play Moola.com its actually fun and free...
click here to join Money games!
its just games with free money!
not 100% positive, but im pretty sure just the batteries...i would still high recommend upgrading to the big 3 if you haven't already. it may have been mentioned earlier, but i havent read the whole post...
no its not done yet. im re doing EVERYTHING after christmas. im going to do everything with 2 runs of 1/0. just one run should be alright for engine ground to chassis?
I just have a question.....why fuse between the underhood batt and rear batts? i mean if say u get a slice in the wire along the frame the fuse will blow but the wire will still be live because of the rear batts??
yea it will be live cause of the rear batteries. they can blow up, not likely, but can. if they do, then you have a big mess to clean up.
That's why some ppl fuse 2wice. Once at the battery under the hood....and another right before the battery in the back. So the wire in between is protected in both directions.
