What is the formula for calculating wiring configurations instead of using the woofer wiring wizard or any program. I am curious about how to wire like 12 subs and I need the formula. Thanks
i am pretty sure its;
parallel
1/x = 1/n1 + 1/n2 + 1/n3 + ......
where x is the final ohm load and the n's are the impedance of the loads your are wiring in parallel
series
x= n1+n2+n3+.....
x is final ohm load, n's are the loads you are wiring in series.
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
x is the resistance per coil and RT is resistance total, for series you just add them
DC.jpgDC POWER
same thing, different format [this one is simpler]
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
depends on what you want for a final load.
all series = 8ohms = 2+2+2+2
series and parallel = 2ohms = [1/ { (1/2)+(1/2) } ] + [1/ { (1/2)+(1/2) } ]
all parallel = .5 ohms = 1/ [ (1/2) + (1/2) + (1/2) + (1/2) ]
this is really confusing i know, maybe you can follow the parathesis [sp?]
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
  • Who's Online   0 Members, 0 Anonymous, 549 Guests (See full list)
