Help with Taramps amp
BassMunky
4 hours ago, BassMunky said:
Which brand Korean amp.man
take your pick -  Deaf Bonce AAK line , Crossfire , Ampere Audio , Incriminator Audio , DC soundlab , Crescendo , etc... they all make good Korean class D amps . i'm partial to Deaf Bonce as i have an AAK4000 & an AAK 180.4 . next year i'll run another AAK4000 at half ohm . what subs are you building with ? what ohm ?? you should of picked up an amp during Black Friday !! i picked up the AAK180.4 for around 310 , but do your research , depending on your subs , get an amp double your RMS , that way you'll be good after impedance rise (box rise) and you get clean non clipped power !! 👍
there is a srcatch/dent Ampere Audio 3800 for 599 from the Amp Lab ...
Aa chaos
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
9 hours ago, BassMunky said:
Aa chaos
the Zcon's  little brother ! , put them on a 4k amp - DeafBonce AAK 4000 , Ampere Audio 3800 , Crossfire 4000  , those are three i would choose from ..
if they are dual 1's , run them at 1 ohm , if they are dual 2 , run em at half ohm ...
There only rated at 700. Rms each
8 hours ago, BassMunky said:
Gotta be able to fit under front car seat. About same size as. A rf 1500 bdcp
then get a JP23v2 2800 watt amp , a little smaller than the fosgate
