Subwoofer Comparison
NOTE: it is very hard to just by looking at some parameters of two well matched subs to tell which is going to do better, there are many factors in play and so you need to go through the whole modeling process to realize the finer details.
Two of those Messo 12 on 3K are about as loud as one EXO 12, so if you are planning to do 1 EXO 12 DON'T do it you will gain nothing dB wise, it would only make sense if you want a smaller box and around same output.
Between the EXO 12 and the Z v5 12 what stands out is the much higher Xmax of the Z (35mm vs 20mm), otherwise they are very similar, So if you are looking for louder and cleaner deep bass the Z is superior to the EXO.
The other thing about the EXO (assuming you want a single one) is that is a D1 so your wiring options are 0,5 or 2 ohm, you need to make sure your amp will deliver the 3000 or so watts at the available impedance options.
If you want to look at some plots or have any other questions, let me know.
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
