Just need a little input here...
Chevy x-tend cab Silverado is vehicle, rear seat is removed and a base floor has allready been created...
Max cubic foot for the box would be about 16... Each BTL will have it own SAZ-3000
3 - 15" BTL's
or
3 - 18" BTL's
Thanks
Team Ampere Audio
id go with 15's because with the 18's you pretty much limited to about 5 cu per sub no where else to go, with the 15's you have more room to experiment with smaller to bigger boxes to get the sound you want..
unless you want to do 2 18's?
3 15's=530.12
2 18's=508.92
so you can see its not a huge difference..
Edited by A&W ROOTBEER
3 - 15" BTL's
or
3 - 18" BTL's
Thanks
if you can get 16cubes after displacement Id go with the 18s, if its before displacement go with the 15s
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
So 18 cubes after displacement go with the 18's... Time for a mini Silverado wall ^_^
Team Ampere Audio
