Deaf Bonce 180.4 crossover settings
So I'm reading the owners speaker manual (Apocalypse AP-M60SQL) it says to use crossover settings HPF at 250-350hz 12db & then it says to use LPF settings of 8k-12k 12db. I will be using the Deaf Bonce 180.4 which in it's manual says that both filters can be used simultaneous. So if I understand correctly while using a cc-1 I should set the hpf to 250 then the lpf to 8k where should i leave the hp, full range, lp switch after I set the crossovers?  Thanks...
