eaglescorpio1 Posted May 28, 2008 Report Share Posted May 28, 2008 I received my alt in the mail last week and just got it put in last night. It is a 225 amp alt, but when i took my car to advanced and had them run an alternator test, the amperage that the machine read was very low. I don't mean 100 amps. It read 14 amps on my stock ground cable, and on a second run on my big 3 ground wire, it read 1 amp. I don't know if I am going about measuring this alt wrong or what. Does anyone know what the deal is? Please let me know the possibilities. Thanks, Joseph Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!! Link to comment Share on other sites More sharing options...
EricM9104 Posted May 28, 2008 Report Share Posted May 28, 2008 What size wire do you do the big 3 with? 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
kentb Posted May 28, 2008 Report Share Posted May 28, 2008 hows ur voltage? New System 2 10" Fi SSD, Sundown 1500d Build I build and design enclosures(cheap price), PM ME Kicker L7 Navigator(plexiglass, fiberglass, aeroport) Build BTL 18" Escalade(plexiglass, battery tray) Build http://www.kentbaudio.com Old System Link to comment Share on other sites More sharing options...
eaglescorpio1 Posted May 28, 2008 Author Report Share Posted May 28, 2008 What size wire do you do the big 3 with? 1. Batt neg to chassis (1/0gauge) 2. Batt pos to alt (4gauge) 3. Engine to chassis (1/0gauge) The reason for the 4 gauge from alt to batt positive is that I was told that for any alternator to charge properly, there had to be a certain amount of resistance. Considering that the alt is only 225 and not a quad 300 setup, the max charge wire I was to run was a 4gauge cable. hows ur voltage?my voltage is great. 14.5 with no load and 14.48 loaded. Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!! Link to comment Share on other sites More sharing options...
EricM9104 Posted May 28, 2008 Report Share Posted May 28, 2008 Why're you freaking out then? You should upgrade the pos wire from the alt to your batt to 1/0ga, 4ga is good for 150a or so. Was your system on when you checked the amperage? If not, don't worry. 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
Stephen Posted May 28, 2008 Report Share Posted May 28, 2008 your alt will only put out what it needs. were you bumping when you did the test? you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER Link to comment Share on other sites More sharing options...
eaglescorpio1 Posted May 28, 2008 Author Report Share Posted May 28, 2008 Why're you freaking out then? You should upgrade the pos wire from the alt to your batt to 1/0ga, 4ga is good for 150a or so. Was your system on when you checked the amperage? If not, don't worry. nope, system was not on, and I spoke to an installer who has done some big spl installs and was told that he had a very in depth discussion with someone at H.O. and they let him know that 4 gauge should be the largest charge cable to run considering the installation, even though it is a 225 amp alt. I plan on looking further into this because most people on here are running 1/0 gauge and how can you argue with results? right? anyways, if anyone has any questions or possibilities, please respond. Thanks,Joseph Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!! Link to comment Share on other sites More sharing options...
EricM9104 Posted May 28, 2008 Report Share Posted May 28, 2008 nope, system was not on, and I spoke to an installer who has done some big spl installs and was told that he had a very in depth discussion with someone at H.O. and they let him know that 4 gauge should be the largest charge cable to run considering the installation, even though it is a 225 amp alt. I plan on looking further into this because most people on here are running 1/0 gauge and how can you argue with results? right? anyways, if anyone has any questions or possibilities, please respond. Thanks, Joseph Cable SizeWire Gauge Current Capacity Amperage (amps) 1/0 350 2 225 4 150 8 100 10 60 12 40 14 25 16 15 From: http://www.the12volt.com/wiring/recwirsz.asp 2015 Honda Civic LX 4dr | 24k miles Stock H/U and mids/highs Power Acoustik GW3-12" D2 Sub HiFonics BXX1200.1D @ 1ohm Random 2.5^3' dual ported box NVX LOC Stinger wiring throughout 1977 Chevy SWB Cammed 350 Dual exhaust Cheap Wish stereo Link to comment Share on other sites More sharing options...
eaglescorpio1 Posted May 28, 2008 Author Report Share Posted May 28, 2008 your alt will only put out what it needs. were you bumping when you did the test?nope, system was not on. more in my response above. Hmmm sounds like I need to get my audison hooked up and pull the 190 amps that my system will pull at full tilt. Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!! Link to comment Share on other sites More sharing options...
eaglescorpio1 Posted May 28, 2008 Author Report Share Posted May 28, 2008 Cable Size Wire Gauge Current Capacity Amperage (amps) 1/0 350 2 225 4 150 8 100 10 60 12 40 14 25 16 15 From: http://www.the12volt.com/wiring/recwirsz.asp i read that not even 5 minutes ago. That is why I am going to contact the manufacturer of this alt and also, I am going to contact H.O. personally and see what they say. Thank you very much though responding with good info. Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!! Link to comment Share on other sites More sharing options...
