Cant Decide- Between 1ohm load or 2ohm load on subwoofers --help
Will wiring two 2ohm sundown U12 1500w  to a 2ohm load sound better? or if two sundown u12 1500w 4ohm to 1ohm load sound better?
Im running a taramps smart 3000w bass amp, which can be wired to both 1 ohm and 2ohm and even 0.5ohm loads.
Which would put them at 1500w rms? So would they sound the same since there getting the same 3000watts but just diiferent ohm's?
Need help deciding, thanks
Post this in the amps section.
With that amp you will not notice any difference and with sound quality amplifiers higher impedance may slightly be better but nothing dramatic.
Usually a bad sub enclosure design, poor electrical or poor gains settings or crossover settings will be far more damaging for your sound quality than wiring impedance.
  • Who's Online   0 Members, 0 Anonymous, 4927 Guests (See full list)
