Subwoofer box design, Need help!!
Tnt78
I want to build a box for 2 12" Down4sound DBz's. I have lots of experience working with wood, the problem I'm having is finding a proper blueprint. The box will be going in a 2003 Chevy s10 extended cab. The space available is 40"W x 22"H x 16"L. The specs on the subs are - RMS OUTPUT: 1300W RMS
COIL SIZE: 2.75 INCH
CUTOUT: 11.26 inches (286 mm)
MOUNTING DEPTH: 7.68 inches (195 mm)
NET WEIGHT: 32.8 lbs (14.9 kg)
GROSS WEIGHT: 36.4 lbs (16.5 kg)
XMAX : 28 mm (one-way)
MOTOR SIZE: 7.48 in - 190 mm | 3.74 inches (Radius)
Displacement: 0.15 cubic feet
Outside Diameter: 12.44 inches (316 mm)
Precision Engineering: Engineered with an optimized motor strength (BL Product: 29.119 T·m) and an effective piston area (Sd) of 59.093 cm² for powerful sound output at an affordable price.
Technical Specifications:
Revc (DC Resistance): 6.050 Ohm
Resonance Frequency (Fo): 35.012 Hz
Total Moving Mass (Mms): 330.724 g
Suspension Compliance (Cms): 62.480 µm/N
Equivalent Volume (Vas): 25.010 L
Sensitivity (SPL): 85.0 dB
Qms (Mechanical Q): 2.322
Qes (Electrical Q): 0.520
Qts (Total Q): 0.425
Mechanical Resistance (Rms): 0.763
Sealed Enclosure: 1.0 cubic foot
Ported Enclosure: 1.75 cubic feet
Any help would greatly be appreciated.
Thank you!!!
For daily use 3.5 net with 50 square inches of port area, tuning 32-35 Hz, dual 0.75 layer baffle, strong cross bracing or window bracing.
BTW Sd is 540 cm² (not what they list)
Thank you!!!
If you decide to do a 4th order blow through I have a design for 2x12s I can send you for Freefitty bro...
  • Who's Online   1 Member, 0 Anonymous, 731 Guests (See full list)
