Help! Noise After Alt. Install
RCA's may be loose or touching something.
Before when I swapped out alts I got mad engine noise. After some testing found out its in the Poopy regulator used in the alt and the lack of noise suppression. But not that kinda sound.
Sounds more like component's than alt, but it is electrical!!!!!
You have good grounds to frame?
Does it get louder or higher with your RPM's?
Shouldn't affect a module any!
MLA
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
i looked over everything again and still nothing. any other suggestions?
Try grounding the alternator with 1/0 to the - terminal of the battery.
  • Who's Online   0 Members, 0 Anonymous, 952 Guests (See full list)
