snafu Posted June 3, 2008 Report Share Posted June 3, 2008 (edited) i was wondering, could it also be that my amp is not getting enough power? My thought exactly. When your amp does shut down, if the Thermal indicator is not lit (1500-1bd that is . . . 1500bd does not have this), this is an indication that the amp does not have enough voltage to operate quickly. The fact that you say that your head unit also shuts off is a gimme - it is also shutting off from under voltage. Takes power to make power. Use this link to get your wiring in order: Clicky Good luck! Edited June 3, 2008 by snafu Quote Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner! Link to comment Share on other sites More sharing options...
deca Posted June 4, 2008 Author Report Share Posted June 4, 2008 My thought exactly. When your amp does shut down, if the Thermal indicator is not lit (1500-1bd that is . . . 1500bd does not have this), this is an indication that the amp does not have enough voltage to operate quickly. The fact that you say that your head unit also shuts off is a gimme - it is also shutting off from under voltage.Takes power to make power. Use this link to get your wiring in order: Clicky Good luck! the HU doesnt shut off, when the sub cuts out, i have to turn off the HU and turn it back on for the sub to come on again. Im running 2awg. Quote Link to comment Share on other sites More sharing options...
dmanson Posted June 4, 2008 Report Share Posted June 4, 2008 the HU doesnt shut off, when the sub cuts out, i have to turn off the HU and turn it back on for the sub to come on again. Im running 2awg. you know one of my old amps use to do that. i lower the gain a tad bit, threw in some better RCAs and it was a wrap, never shut off again. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module Link to comment Share on other sites More sharing options...
