2007 chevy cobalt stock alternator upgraded to Big 3.
Crunch GP 3000.
is a Kinetic Hc 2000 enuff for back up, or do I need a 2400?
I'd like the 2000 just for price reasons, would this be safe?
opinions please.
I can't afford a 200 amp alternator.
most likely I'd run the amp at 2 ohms.
Fear The Quack!
Shot at 2007-08-19
I would really go with the 2400 to be safe and maybe a bigger bat up under the hood also that amp pulls 300 amps wich is alot for even just 1 2400 with the stock alt
Crunch GP 3000.
opinions please.
how much you paying for that kinetik 2000 model? you can probably get a power master basttery thats strong for equal or less here
http://www.jegs.com/p/Powermaster/795651/10002/-1
# 713-D3100 XS Power 12V AGM BatteryGroup 31 deep cycle battery
# 77.16 lbs
# *Amp/Hour: 117
# Max Amps: 3200
# 13.03" L x 6.89" W x 8.43" H
that one would work good?
it's over 3000 amps, or is that over doing it?
i'm looking for $200-300 dollars preferablly $200-250.
pick out what you think I would need and i'll go with that.
I think my default voltage is 14.
Fear The Quack!
Shot at 2007-08-19
# 77.16 lbs
# *Amp/Hour: 117
# Max Amps: 3200
you can never over do it..and i would pick the d3100 over the kinetik hc2000 ive heard much better things about the power master..look at it this way..if steve's using them in his 30k watt system then you know they will hold up well for your needs..lol
if I can come up with it i'll get that, if I can't ill go one model lower.
thanks guys.
Fear The Quack!
Shot at 2007-08-19
  • Who's Online   0 Members, 0 Anonymous, 1396 Guests (See full list)
