banginAltima Posted June 10, 2008 Report Posted June 10, 2008 Looking for a good line output converter, brand, model, cost, with or without remote turn on. This is for a 06 Nissan Altima with the Bose system. If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
Aaron813 Posted June 10, 2008 Report Posted June 10, 2008 I think that AudioControl has one but im not sure
Aaron813 Posted June 10, 2008 Report Posted June 10, 2008 Here is the top of the line Stinger http://www.woofersetc.com/index.cfm?fuseac...Product_ID=6190 Here is the another stinger one but doesnt have as many function http://www.woofersetc.com/index.cfm?fuseac...Product_ID=5795
reinke Posted June 10, 2008 Report Posted June 10, 2008 Pac tool model #sni-15. should be under $20 ----reference's---- meade916
banginAltima Posted June 10, 2008 Author Report Posted June 10, 2008 I guess I should ask... what do I need to look for in a line converter? I am just looking for something to allow me to use the subs just to listen to the radio. If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
Aaron813 Posted June 10, 2008 Report Posted June 10, 2008 I guess I should ask... what do I need to look for in a line converter? I am just looking for something to allow me to use the subs just to listen to the radio.The cheaper of the 2 Stingers i posted will work just fine then ive used one before and it worked just fine PStone11 on here has all used one I think the same one so he might have some feedback for you on it
ISO Posted June 10, 2008 Report Posted June 10, 2008 Here is the another stinger one but doesnt have as many function http://www.woofersetc.com/index.cfm?fuseac...Product_ID=5795 If you want something simple to run an external sub amp.I second this item. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
banginAltima Posted June 10, 2008 Author Report Posted June 10, 2008 The second one looks pretty good. Just being lazy.... do you wire it in before or after the factory amp? If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
Aaron813 Posted June 10, 2008 Report Posted June 10, 2008 The second one looks pretty good. Just being lazy.... do you wire it in before or after the factory amp? I would think after the car I put one in didnt have a factory amp
ISO Posted June 10, 2008 Report Posted June 10, 2008 I would guess after the factory amp. Try it and see what it sounds like. I don't know if you would get the propper voltage for that item if you put it before the amp. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
