Looking for a good line output converter, brand, model, cost, with or without remote turn on. This is for a 06 Nissan Altima with the Bose system.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
I guess I should ask... what do I need to look for in a line converter? I am just looking for something to allow me to use the subs just to listen to the radio.
I do box designs.
The cheaper of the 2 Stingers i posted will work just fine then ive used one before and it worked just fine PStone11 on here has all used one I think the same one so he might have some feedback for you on it
Here is the another stinger one but doesnt have as many function
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=5795
If you want something simple to run an external sub amp.
I second this item.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
The second one looks pretty good.
Just being lazy.... do you wire it in before or after the factory amp?
I do box designs.
I would guess after the factory amp. Try it and see what it sounds like.
I don't know if you would get the propper voltage for that item if you put it before the amp.
  • Who's Online   0 Members, 0 Anonymous, 1521 Guests (See full list)
