Box For Fi Bl 18 In Ford Explorer
Does anyone happen to be able to make a design for a ported box for a Fi bl 18? I saw on another forum where people asked this one guy to design a box to the specs of the sub and he would make a CAD design and then post the pic and deminsions. I forgot where this forum is.
I just built a box for it but it's solid, not ported, the bottom plate for the box right now is about 28" by 24"
It's the Dual 2.
BL18
DUAL 1 | DUAL 2
Fs: 33.1 Hz | 32.5 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 6.43 | 6.54
Qes: .53 | .49
Qts: .49 | .46
Mms: 280g | 290g
Cms: 0.13mm/N | 0.13mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 169.7 l | 169.7 l
Spl: 92.5dB 1W/1m | 92.6dB 1W/1m
Bl: 12.8 N/A | 19.0 N/A
Xmax: 21mm
Rms: 1000W *
Sealed box: N/A cuft
Ported box: 5-10 cuft @ 30-37Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 9.750”
Displacement: 0.23cuft
i do box designs for a small fee, amatt on here does them for free i believe and has a thread in the enclosure section if you wanna go that route.
I own a ford explorer and have ran many 18s in it as well if that helps, either way just let me know
