in my truck right now. i got a head unit that i pulled yout to changet he rca cable no big deal. but went to put it back in and never came back on....took it back out and the yellow bat wire is loose....so tried to put it back in and still nothing but the conection seemed bad. i also checked the 15a fuse that the wire runs though....any sugustions?
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
Did you check the radio fuse thats in the fuse panel for the car.
There might be 2 of them.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
no i havent. what size fuze it it ive never had to check one bf
...could it of blown the fuze for the wireing being pulled loose?
1 3500d AQ amp
yes that wire is a 12V constant for memory. and usually its like 10-15 amp fuse you just have to check.
checked the fuses...the fist one i pulled out of like 10 was blown so that is the prob...thanks for the help guys
1 3500d AQ amp
still nothing
1 3500d AQ amp
Does your spedo work I had two fuses. One blew I fixed it(inside the cab) radio came on till I shorted my remeote wire that fuse was believe it or not under my hodd that one caused my radio and spedo to go out.
  • Who's Online   0 Members, 0 Anonymous, 799 Guests (See full list)
